Driveshaft Failure!!!!!!
Ok, so..in my infinite lack of mustang knowledge it has been brought to my attention that my 110mph habit on a stock driveshaft spells d.i.s.a.s.t.e.r. So please people steer me in the right direction for a shaft capable of holding up against let's say 140+ mph????
RE: Driveshaft Failure!!!!!!
Well .. my Aluminum ShafterMaster DS hit almost 130 MPH today on they dyno ....
https://mustangforums.com/m_4829827/tm.htm
ok, I watched your vid and you're telling me the X only put you to 271? Don't they advertise 300+??? $4000+ is a much for only 60 extra horses over stock...but ok, aluminum shaftermaster can do at least 130mph. Anyone else have higher numbers and links for a drive shaft?? I am an idiot over here...so much so I thought my car was satin silver until I looked at the paint code T8 and read it is tungsten gray lmao
That is 271 Rear Wheel HP .... Which is about 320HP NET ... Factory is only 210HP Net ... and around 175/180 at the wheels ...
I guess that is your infinite lack of mustang knowledge showing ...
What year is your car? The 05's had their driveshaft U-joint bearing caps peened in. Later models have the retaining clips. The clips are much more reliable. I haven't heard or seen any of the later style failing. Not saying it hasn't happened,because even the best have bad apples. I would totally be for itif you've got an 05 with the peened in caps.
2005 or 2007, I'd still upgrade to a new driveshaft. Stockers aren't that great from what I've seen. It should be a great investment. Aluminum is the way to go. But if you're trying to go 140...do you have your car tuned so you don't have a governor? If not, you'll need to do that if you plan on going past 115. That's the average that our car cuts out at.
