Worth a Tune?
RE: Worth a Tune?
Are you planning on getting a bigger intake? I noticed ahuge difference, but I went with the C&L intake at the same time. I don't know if you will see as much of a gain with the aircharger system installed. It flows, but it's still the same size MAF housing as stock so it doesn't require a tune. Am I correct? I agree the tune will make the response better, but I can only tell you how my car feels with BOTH the intake and tunes.
RE: Worth a Tune?
You are correct about the K&N not requiring a charge but what most people have said even people at vmp, bama, and brenspeed have all said that for the money getting a bigger air intake system ain't worth it. That kind of adds to my delimma because if I didn't already have a K&N I would definitely go with a C&L or JLT with the tuner no questions asked. But since I have the k&n and have been told its not worth it to upgrade then is it worth it to get a tuner esp if probably just going to use the 87 tune
RE: Worth a Tune?
Yeah, I looked up the price on the aircharger, quite expensive for what it is. I'm not going to say they(C&L,VMP, etc,)are not a worthy upgrade, those intakes move more air, but in your case, it would be costly, and the gain wouldn't be worth the amount you would have invested in the K&N paperweight and buying a new intake.
RE: Worth a Tune?
ORIGINAL: Yellow Tang
If you have an auto trany you should see an improvement even with a 87 tune. High-octane fuel adds ZERO more HP to your motors Output. So you can go with the 87 tune just fine.
RE: Worth a Tune?
ORIGINAL: themac5150
You're right, but the 93 octane tune with 93 fuel does. The 93tune uses advanced timing the 87 fuelcan't handle. It's an easy HP grab, we just can't spin the distributor to get it.
RE: Worth a Tune?
That's why if you bought a new intake, it would become a paperweight, or garage art.
ORIGINAL: vtmustangs
I already have the aircharger setup
RE: Worth a Tune?
I dont think a tuner is worth paying for if you are using 87 octane tunes. I went to an 87 Performance tune from a 93 performance tune. The 87 feels like I took my CAI off and put my old airbox back in. I'm driving out of my way to work to run out the tank of 87 octane.....if you commute a lot, the 87 mileage tune might be the only reason to purchase a tuner.
