Need HELP before its too late!
So, I gave up on trying to sell my rims/tires, so I got them installed into my car. But man! What a difference over the stock V6 rims! Chrome definately makes a car look considerably different.
But here is the problem...
I ordered my rims/tires from americanmuscle.com and had them do the balance and mount for free. All four rims/tires came in four boxes, they said all I had to do was put them on and I was good to go. But I'm lazy, so I took them to Tire Kingdom and paid $20 to have them put it on for me. Thirty minutes later, my 05 black mustang has an incredible set of s-style 18x9 front and 18x10 back with 255/45 nitto555 front and 285/40 nitto555 back. Awesome.
Then my brother said to drive with him standing behind the car, he was skeptical that the tires were too big. They aren't, but the thing is, the driver side rear tire sticks out slightly more than the passenger side rear tire. And my brother says it has a slight wobble to it. My friend looked at it from behind too but didn't notice any wobble.
So I looked at it from behind. I don't really notice a wobble, but I DO notice that the driver side rear tire sticks out a bit more than the passenger side rear tire. I took it back to Tire Kingdom, but they said they put them on, all the bolts/nuts are on tightly, and thats it. He even tried shaking the tire and **** for some reason to show me how good they were put onto the car.
Does anyone know what the problem could be? I did have a Ford Racing T-lok installedfor my V6. Would that make any difference? Otherwise, my car is stock in that department. I need to know if I should get it checked out or if I am freaking out about nothing.
RE: Need HELP before its too late!
you probably got wheels with different offsets. as long as you didnt lower the car you wont need a new panhard rod. have tire kingdom check the wheels to make sure theyre the same. have them look at them on the car. you might need a spacer or a refund.
I am so GOD DAMN PISSED OFF right now. Not only at myself but at ****ing americanmuscle.com
On my invoice, it SHOWS I ordered NITTO Extreme Performance NT555 Tire (255/45-18) x2 and NITTO Extreme Performance NT555 (275/40-18).
So, I went outside just a moment ago to check my tires. Because I looked at website again and noticed different numbers....
And guess ****ing what? They sent me (265/35-18) x2 for the front and (285/35-18) x2 for the back. How did they manage to fit them on the rims I ordered? Not sure. But I just found out, because I was so stupid and anxious and trusting to the website, they I didn't realize the different tire sizes.
So now, I have to call them tomorrow so see what I can do. They will probably say, "It's on your car now, not our problem." And if they say anything like that, I'm never ordering from them ever again. God, I just hope these tire sizes will not **** up my car or rims or anything....
This mustang is stressful....
Well, they sent you wider tires than what you specified-- which I don't consider a horrible mistake, because to me at least, wide tires look good. The sidewall is probably shorter though, and that means that your car needs lowering springs to eliminate the large fender gap that becomes more apparent when you run a shorter sidewall tire. The wider tires fit on your rims just fine. I have a 295 width tire on a 10" rim.
What about the whole one tire sticking out more than the other thing?? My first thought was that your rear rims are not the same offset.
ORIGINAL: AmericanICON
