Door Panels - Leather Inserts
Old 04-12-2008, 10:38 AM
themac5150
themac5150's Avatar
Default RE: Door Panels - Leather Inserts
Ok, I found the site, but he just did the rear rests, the front was factory apparently.
http://www.cherod.com/mustang/
I haven't really looked into doing this, but it appears the same can be done for the front if the arm rest/map pocket comes off easily. Add some piping and it'll look sharp.
themac5150 is offline
Old 04-12-2008, 01:22 PM
conor1148
conor1148's Avatar
im slightly confused. are you looking for the leather pieces to put on the inside of the door?
i would check this place out, im thinking about getting some seats from them to match my windevil blue mustang.
http://www.mustangupholstery.com/lat..._products.html
go to the "sell sheet" to see all their colors.
conor1148 is offline
Old 04-12-2008, 04:15 PM
landon.moss
landon.moss's Avatar
it's not difficult....i'm just guessing here, but if it's done logically, you'd take your material, use spray adhesive and mount it on, then trim off your excess to finish it off (probably have to use rubbing alcohol on your panel to remove wax, cleaner, etc.)
think i'm just going to run chrome (all black interior) around the insert like some do the colored welts
ps looks pretty sweet
landon.moss is offline
Old 04-12-2008, 07:46 PM
pat123
pat123's Avatar
I was told by the upholstery shop that if you try to glue this on it will let go when the interior gets hot because of the curve in the panel. He said that was the reason that the factory panels that were covered had small holes in them.
pat123 is offline
Old 04-12-2008, 08:53 PM
themac5150
themac5150's Avatar
You can't get the color material you want perforated?
Old 04-12-2008, 09:05 PM
NocturnalV6
NocturnalV6's Avatar
I want lol
NocturnalV6 is offline
Old 04-12-2008, 09:51 PM
2007Grabber
2007Grabber's Avatar
If you have the IUP with the leather on the door inserts, you could have it done. If you don't have leather door inserts, you woud need to buy new door panels.
2007Grabber is offline
Old 04-12-2008, 10:00 PM
NocturnalV6
I have been wanting custom interior for a while, but my cloth ones say mustang in light gray all over them, and I kinda like that. So if I could find custom stuff with mustang or "sandman" all over them I would do it
Old 04-12-2008, 10:13 PM
mikethebikerboy
mikethebikerboy's Avatar
it looks good! i want to get my interior done.
mikethebikerboy is offline
Old 04-12-2008, 10:16 PM
NocturnalV6
anyone know of a place in AL that does this stuff?
Quick Reply: Door Panels - Leather Inserts
