gona do first oil change at dealership but have a question??
going to do first oil change and i want to go to the dealership but what about the mods that i have on. i have the sct 3, c&l intake and flowmasters. will they void my warranty if they see the mods. cause im scared theyll do that when doingthe oil change.
RE: gona do first oil change at dealership but have a question??
No. But if something does go wrong and they find the cause to be one of your aftermarket mods, then yes. I'm sure the dealership has seen a plenty of modded Mustangs too.
i know that if later on something happens to my car ill take them off before going in to check. but just wanted to know if on the oil change they would screw me.
why not change yourself, takes about 15 minutes w/ floorjack and jackstands. takes me longer to drive to the dealership than it is to change it myself. i'm no mechanic, but i can change the oil pretty easily. but anyway i dont think the CAI will make a difference.
you might as well do it yourself...the only plus side is that for not too much more, they'll fill all your other fluids, and do their other checks as well....but, it costs more, takes more time, etc.
i called around, and the dealer in my home town said he wouldn't recommend doing too much to the car, but he said exhaust is cool as long as you don't mess with the cats, don't do a cai (he told me that if something happened anywhere with the motor they would blame it on the cai regardless of whether or not it would have caused the problem - some dealers may be different, but that is this one's policy. unless, you buy a ford racing one and they install it, then you must keep the receipt from install), hi-flow filter ok, and computer tune can't be traced if you re-setto stock anyway.
I take mine in to get the oil changed all the time and they never touch anything. If something happens to your car just put all the factory stuff back on before you take it in.
ORIGINAL: tamazulense
