Jet Preformance Module
Performance Modules by JET, adds 30+hp,
http://www.mossmustang.com/Shop/View...eIndexID=51317
Would anyone reccomend this or does anyone have any better suggestions, i dont want to spend any more than $250
RE: Jet Preformance Module
Just save up for an SCT Xcal2 tuner. Do it right the first time.
It's like getting a paint job for your car in mexicali for 1/4 of the price it would be in the states... you just don't do it.
The JET Ford Module optimizes the ignition spark advance, air to fuel ratios and transmission shifting for the ultimate in power and mileage gains. JET's exclusive Dynamic Spectrum Tuning provides optimal performance across the entire power band-not just at full throttle, making it idle for towing and around town driving.
Its too good to be true
It's a piggy-back tune system. It will not give you anymore than a regular tune from a sct or diablosport device. I've always heard bad things about these on obd-2 style systems. On top of that if this system fails it can do damage because it intercepts all computer signals and sends an altered version of what the pcm trys to make the car do.
I would save up and get an x-cal 2 or 3 so you alter the actual tune but still get all of the safety backups of the pcm
i checked out the x-cal 2 and id rather go for the x-cal 3, My car is completley stock at the moment and i have a lag when i gas it, will this get rid of my goveners and is it easy to use, i work on classic cars and dont know much about the electronics or the computers.
yes, it will rid your car of the lag. get your xcal3 from a tuner shop so that they supply you with custom tunes instead of just the default tunes that come with the tuner from the manufacturer. if you decide to get an intake later, they should modify your tune at no extra cost. thats what bama did for me when i upgraded from an AEM to my current C&L intake. good luck dude.
