Weird RPM problem...
Okay, first off, I own a '07 4.0 Automatic, and I noticed something weird with the RPM's on normal driving.
I don't know if this is a problem or whats wrong, but when I'm cruising at like 40-60 mphish (normal driving, AC off), when I slightly press on the gas, the RPM stays at around 1.5k rpm and does not move... I hear the engine roar a little bit but the RPM's do not move past 1.5k. When I put a little more gas it still kinda doesn't do it but when I press it more it kinda bogs forward and jumps the rpmg to like 3kish..
I only have 4050 miles on the car, there shouldn't be anything wrong with the car...
Any ideas on what it could be?
RE: Weird RPM problem...
That's what mine does as well when it's in 5th gear the bogging is when it shifts back down to 4th while you push the gas harder. If you want to get the rpms back up before you press the gas just press the O/D button off on the shifter which will bring it into 4th gear then your rpms will jump a bit and yeah.
I dont' think it's an issue with the car but if it is i guess i got to get mine checked when i bring it in for the recall(which i still have done oops)
I'm not saying it's a "problem", just that the car, if you're not under a load, just cruising around 50mph, it's probably in top gear. It's an automatic, all of my past cars with autos responded like that. The computer wants to keep it in overdrive until IT determines that a downshift is required because you want to accelerate. If you floor it, does it act the same way?
No, past a certain point of pressing the gas it downshifts and raises the rpms. But if I'm just cruising the RPM's don't bounce at all, freezes at 1.5k. Overdrive off, it goes to 2k rpm and when I press the gas lightly it shifts between 2k-2.5k, but with it on it just freezes at 1.5k rpm..
