FRPP duals ordered! - Pics added
Just got back from the dealership, they should be here wednesday or thursday. I'm so excited, just love the feeling of getting a new mod for the car.
Anyway, I want to install them myself and have a couple questions. My friend works at a dealership so ive got access to a lift and some tools. Are there any parts of the install that are somewhat tricky or not covered clearly in the instructions? What did you use to cut the Y Pipe?
I installed the aeroturbine myself, but haven't done anything like a catback install before and don't want to end up messing the install up. It will be on the car by friday one way or another and I'll post pics as well as my thoughts on power/sound vs my aero turbine.
RE: FRPP duals ordered!
If you are using a lift, the tricky part is already solved. The hardest part of the install for me was snaking the mid-pipe over the axle with the car on jack stands. It was pretty aggravating. Cutting the y-pipe was not fun with a hack saw either, but I Tom Sawyered my 17yr old son into doing it. Oh yeah, if your using the black cutout trim pieces, those were a real PITA also. There's just not much room between the fascia and metal bumper in that area. Doable, but not fun.
Yea, the cutout trim screws are a real pita, not much room to get the nuts on and I had to go back later and cut the top screws off cause they vibrated against the bumper cross brace. I used a chain cutter to cut the Y, but a sawzall would work fine. Use the stepped band clamps on the Y that come boxed with the X, and yes, you will have two extras. Enjoy the sound
If you are using a lift you should have no problem installing the kit. Follow the instructions carefully(especially measuring and cutting the Y pipe)and the kit goes together nicely. Use a sawzall or even a hack saw, its only exhaust pipe and cuts easily. Take your time on the bumper cutouts, theyARE a pain. You will love the way the kitlook and sound! Good Luck!
A sawzall type saw works the best.
It took me & my son-in-law only 1-1/2 hours to do.
It was on jack stands, and getting the old pipe out was the hardest part.
And yes you will have 2 extra clamps.
Some report that you are short 2 bolts in the box for the muffler hangers but if you pull off the extra hanger on the passenger side that is not being used anymore you will have the other two.
ORIGINAL: 05_mustang
I didn't have a problem with the flanges or bumper cut-outs. They aren't easy, but if you just take your time and have the right tools, they go in pretty smooth.
Or you could just get a GT take-off bumper
just picked up the box from the dealership, dayum those tips are huge!
I'm gonna cut that bumper today and do the install tommorow, the template for cutting the bumper wasnt in the box, so i had to print it from online. kind of pissed me off that it wasnt included
