Burning Smell....
Old 06-24-2008, 10:01 PM
  #21
bmr251
bmr251's Avatar
Default RE: Burning Smell....
I've had the same faint rubber burning smell since i got my sportlines and hand tuner, i thought maybe it was from the wheel rubbing really slightly against the well or something like that, but a friend of mine said it just smelled like hot engine. i adjusted the temp at which the fan kicks in (on the hand tuner) a few days ago n so far so good (knock on wood)
bmr251 is offline
Old 06-24-2008, 11:08 PM
  #22
vb101
vb101's Avatar
I got the same burning smell. It comes and goes. As it turns out the smell from mine was from the transmission. The T5 gets very hot and in my case there was a little too much oil in the transmission so when it heated up some small amount of oil was blown out through the vent underneath the transmission and ran along the transmission then flung around underneath the car with some of it getting on the exhaust. I could see the oil underneath the car and along the bottom of the transmission leading from the vent to the end of the tail shaft.
vb101 is offline
Old 06-30-2008, 08:04 PM
  #23
So_Cali
So_Cali's Avatar
After doing some snooping around, I think I found the source. It appeared to be a plastic bag that was melting/melted. I wasnt quite sure. For those that have had the plastic bag problem LOL what did it look like?
So_Cali is offline
CS2007
06-25-2019 09:45 PM
lincolnshibuya
12-08-2015 04:37 PM
jhawkr
10-30-2015 01:55 PM
jrrhd73must
10-02-2015 09:17 PM
jpplaw
08-22-2015 09:29 PM
Quick Reply: Burning Smell....
