GT Grill in a V6
RE: GT Grill in a V6
The shape of the front facia is a bit different around the headlights. As a result, the GT grill won't fit in a V6 bumper and a V6 grill won't fit properly in a GT bumper. Ford made them just different enough for the fit to be off.
A V6 grill can be put into a GT bumper but you will have some gaps. The GT grill is a little too big and won't fit in the V6 bumper.
I get the feeling that you want to know, specifically, why it doesn't fit well. As you know, the grills are somewhat beveled in the back. The GT grille is beveled at a different angle than the V6. It's not much, just enough to be a real pain in the a**. Also, the GT grille is taller, so it will stick up slightly. The tabs on the back are different too. The lower tabs on the GT are different than the ones on the v6. This isn't a big deal, because the lower tabs may be removed, the side tabs are in the right place. I tried to install a GT grille on my '05. It took a tremendous amount of force and when I was done it had a kind of "Frankenstein" effect, you know, close but not quite right.
I pulled it out and went with a Street Scene grille. The install was a piece of cake!
So your getting the Whole GT front bumper? thats what im going for and while your at it, get the clear corners, they look sick! http://www.americanmuscle.com/2005-t...hts-clear.html
as for the tuner, id go for the X-cal 3. something i want but cant afford. a lot of the guys on here have them so feel free to ask questions.
you have good plans, good luck
Here is a fewpics of a GT grill crammed into a V6 bumper.
Yuck. The mounting tabs are also different in quantity and location.
All of the bottom mountingtabshave to be cut off the GT grill to
even start to go into a V6 bumper. And the four side tabs barely line up. [:'(]
[IMG]local://upfiles/69445/FEBABEC0237C4D3F88F959E8051FEC47.jpg[/IMG]
[IMG]local://upfiles/69445/D1C6502EBB4E4E248878FC4E0F40E7DC.jpg[/IMG]
ORIGINAL: ptkthekid
You can get a GT style grill for a V6 on ebay for about $400
How is the fitment?
I hear that sheet metal bending is
required forsome V6 to GT style grills.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
