Plugs?
Old 07-04-2008, 02:03 PM
BWfVA
BWfVA's Avatar
Default Plugs?
What kind of plugs would you recomend. I just bought a Screamin Demon coil and some 8.5 MSD Super Conductor wires so what kinda plugs would you recomend and where would you find them at because nobody but the Ford dealership carries plugs to fit our cars.
BWfVA is offline
Old 07-05-2008, 12:18 PM
BWfVA
BWfVA's Avatar
Default RE: Plugs?
You cant tell me nobody on here doesnt run something besides stock plugs
BWfVA is offline
Old 07-05-2008, 02:25 PM
4.0 $tang
4.0 $tang's Avatar
Default RE: Plugs?
arent you supposed to run only LiveWires with the SDC.....
4.0 $tang is offline
Old 07-05-2008, 03:47 PM
Wishbone
Wishbone's Avatar
Default RE: Plugs?
Yeah you need the Livewires and I would run Ngk platinums.
Wishbone is offline
Old 07-05-2008, 10:44 PM
BWfVA
BWfVA's Avatar
Default RE: Plugs?
Oh well the MSD Superconductors work great with that coil, I noticed a difference, not big but a difference. They are 8.5mm and they are made about the same as the Livewires.
Does anybody have any experince with the Bosch Platium 4+, I got them but I havent put them in so I can always take them back.
BWfVA is offline
Old 07-05-2008, 10:54 PM
Bandit111
Bandit111's Avatar
Default RE: Plugs?
I have no personal experience on this,but i saw at least one pic of a pretty eaten up tip and i believe it was a bosch 4+ SD combo(have to look for it again).I believe the whole purpose of this coil is to be able to run a wider gap and still get a good strong spark.
Bandit111 is offline
Old 07-05-2008, 11:27 PM
BWfVA
BWfVA's Avatar
Default RE: Plugs?
Yea that was the point but if all the extra juice is going to fry the tips then i guess I will go to the stealership tommorrow and buy some FRPP Plugs or something similar.
BWfVA is offline
Old 07-06-2008, 05:56 AM
Moderator
JimC's Avatar
Default RE: Plugs?
I bought my new plugs at Advance Auto. They had a wide selection, including the Ford OEM style. You should be able to find plugs at places other than the dealer parts desk. You can also check with Murray's (www.murraysdiscount.com) which has some connection to Advance Auto and online you can see all the plugs they have available.
JimC is online now
Old 07-06-2008, 10:45 AM
mustangman02232
mustangman02232's Avatar
Default RE: Plugs?
go to autozone and get a set of autolights
i had Halo plugs in my old stang which i really liked
mustangman02232 is offline
Old 07-08-2008, 01:03 AM
fullmonte60
fullmonte60's Avatar
Default RE: Plugs?
i've used ngk iridiums & were happy with them. i picked up a set of e3's (part# e.360) last w/e and will put them in when i install my new headers thid w/e.
fullmonte60 is offline
Quick Reply: Plugs?
