New exhaust with HI Temp Paint
Changed over from the JBAaxleback to a GT take off. JBA was welded because of fit issues so i needed a new midpipe. (Thanks Ryan) Bead blasted the midpipe and cleaned up the muffler with a wire brush. Painted both with a 1500 degree Hi temp Flat black to hide from behind. Muffler pics don't show as well as mid pipe. GT Muffler sounds much better than JBA. JBA had a Rice Burner sound to it on acceleration. BTW If you ever have to change over your midpipe it is a PITA. The angle you need to put it over the axle requires the vehicle to be on a lift. I had to drop the rear axle and suspension to get it in. 2.5 hours of work and 1/2 hour of swearing. Overall happy with the end result especially with the B@M@ tune 93 race. Traction control came on for the first time from a dead start.
[IMG]local://upfiles/74535/0A433C9123774FC08BBDF29C2C8C5DBC.jpg[/IMG]
[IMG]local://upfiles/74535/5D1C069CAE714611ACF9E718C364560D.jpg[/IMG]
[IMG]local://upfiles/74535/F7D0D22B35E6472AB570389D9DA9E45A.jpg[/IMG]
[IMG]local://upfiles/74535/64749949A9EF4E39993375096F2D372A.jpg[/IMG]
[IMG]local://upfiles/74535/39E96D2372084EAD93187CFCA94394BD.jpg[/IMG]
RE: New exhaust with HI Temp Paint
ORIGINAL: dwagner825
A little bit of twisting and you can get a midpipe (I assume you're talking about the over-axle pipe?) on in no time at all.
ORIGINAL: raubt
Incorrect.
I had the same issue so (stupid me) put the jack on 3 2x4's and it gave me jus enough clearence to wiggle out my old mid pipe. but yes there was swearing involved when i tried just on jack stands
ORIGINAL: raubt
Incorrect.
If your'e looking to do it again and switch to duals I'll have my GT Mids and Mufflers for sale soon.
ORIGINAL: 95cobby
I second this. If you jack up the car by jacking up the rear end then yes good luck getting them over the axels. Jack the car up by the frame and let the rear end hang. I took off my stock mid and put GT mids on all in about 5mins tops...
ORIGINAL: raubt
Incorrect.
.......GT Muffler sounds much better than JBA. JBA had a Rice Burner sound to it on acceleration.
ORIGINAL: Sancho805
must be that the JBA is better suited for duals. my setup sounds great. nice muscle tone throughout the rpm band without getting excessively loud. i guess the H-pipe makes all the difference .
like i said, the h-pipe must make all the difference.
good info for those looking at getting a single JBA. i always recommend the GT take-off for singles anyways. cant beat the price+quality.
09-10-2015 08:39 PM
