Ninosport duals?
Ninosport duals?
Has anyone ordered the Ninosport dual exhaust? Here is the link http://www.ninosport.com/Ninosport-D...;category=-108. I would be using bassani axlebacks off of a GT. Any input would be helpful. Thanks.
RE: Ninosport duals?
this is a great kit extremely easy to install, and they send you all the parts you need! i installed it myself on my car (and i am no "gearhead"). it took me about 2 hours to remove my old exhaust and bumper, then install new exhaust. Stop to turn the car on and drool for a while, then install the new bumper. if you have any more questions, concerns, etc, i would be more then happy tp help.
The only true "bolt on" system that I've seen. I don't like the other systems because you have to cut your Y pipe. That makes me nervous. I think It's affordable and fairly easy to install. Get this kit and a set of GT takeoffs and you have a nice dual set up that is really affordable!! If your not a "gearhead" this a great place to start. A perfect beginner project!! Actually, It's next on my personal Mod list. Good luck!!!
^Oh by the way..... You will have to cut your rear bumper for the second tip. I think this is the hardest part of the install. While I haven't done it yet I'm told that it's fairly easy. I hate to see people throw $300 at a GT rear bumper when thay could use it to get another mod. Good luck!!!!
ORIGINAL: wrestlinnut
Thanks for the input guys! I will place my order sometime next week. Do you know if they give discounts to forum members? Im guessing this kit sounds great?
06roushv6,
Did you have to put any type of heat shield over the driver side exhaust? Also, was there much play with the system as far as having the ability to slide the GT takeoff exhaust forward or rearward as required to get the pipe to stick out the back and centered for that matter?
