Rear spoiler help!
Old 07-31-2008, 01:19 PM
The Torch
The Torch's Avatar
Default Rear spoiler help!
Hey guys, imgoing to take off my V6 rear spoiler and add a GT take-off spoiler. Ive been looking for installation instructions online but cant find anything? Do you guys know where i can find them? Any help would be appreciated!
Thanks
The Torch is offline
Old 07-31-2008, 01:45 PM
A_Drunken_Llama
A_Drunken_Llama's Avatar
Default RE: Rear spoiler help!
open the trunk and unscrew the bolts, then carefully pull the spoiler off. do it on a hot day or use a something to heat up the "glue" between the spoiler and the trunk....it should come off pretty easily
A_Drunken_Llama is offline
Old 07-31-2008, 02:03 PM
The Torch
The Torch's Avatar
Thanks, i guess they use doulbe sided tape? When i attatch the new one will i use the same and if so where would i get some at the local hardware store?
Old 07-31-2008, 03:14 PM
95cobby
95cobby's Avatar
ORIGINAL: The Torch
I don't think youll need any tape. It should just bolt on.
95cobby is offline
Old 07-31-2008, 03:54 PM
157dB
Cut & Paste Expert
157dB's Avatar
Yes, you need the mounting tape to make the install watertight.
The Ford dealership has the required tape. Dont overtighted the
mounting hardware as you can deform the trunklid. [&:]
http://iihs.net/fsm/?dir=443&viewfil...ler%20Rear.pdf
44 in/lbs torque spec on the nuts
http://iihs.net/fsm/?dir=442&viewfil...IFICATIONS.pdf
157dB is offline
Old 07-31-2008, 03:58 PM
p51mstg
p51mstg's Avatar
ORIGINAL: The Torch
Everything you need to install the new spoiler should come with the spoiler. The new spoiler shouldcome withdouble-sided tape, or at least some sort of gasket to keep water from leaking through the holes. If it wasn't shipped with something like that, maybe you can re-use the stuff fromyour oldspoiler.
The GT spoiler uses the same mounting holes as the Pony spoiler. Like was said, unscrew all four bolts under the spoiler. Then, close the trunk lid.
I would not use a heat gun, because of possible damage to the paint. This time of year, if you did this in the sun, it should be plenty warm.
Some people have used fishing line to "saw" through the tape, but I had trouble with that. I finally just kept pulling on one end of the spoiler until it popped off. Be careful about where it lands if it does pop off, because mine lifted off the trunk about a foot and scratched my trunk on impact.
Much to my dismay, the Pony spoiler left marks on the trunk paint where it was rubbing. Ford has since put out a TSB on that, and the suggested "fix" is to add double-sided tape where it rubs (wow, thanks for the help,Ford).
p51mstg is offline
Old 08-01-2008, 02:18 PM
Elcameeeno
Elcameeeno's Avatar
I picked up a GT spoiler to add to my spoiler-less car. Is there anywhere online to get a template for the holes?
(Sorry for hijacking this post)
Elcameeeno is offline
Old 08-01-2008, 02:46 PM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: Elcameeeno
Nope, not online. You are going to have to measure, measure, measure.
Transfer the measurments to painters tape.
Obtain gasket material from stealership and drill the 4 holes needed(yikes).
Or swap trunk lids with a Forum member who wants the spoiler delete option.
[IMG]local://upfiles/69445/F717560C2C824336881F7CEA8EF2B90A.jpg[/IMG]
[IMG]local://upfiles/69445/D726CA4AA6194AE6BBCF6D43450B3D8F.jpg[/IMG]
157dB is offline
Old 08-01-2008, 02:47 PM
A_Drunken_Llama
we're talking about spoilers...so u're good....u didn't hijack it
the Ford dealership should have the template....I know mine does
Old 08-01-2008, 03:52 PM
Elcameeeno
Elcameeeno's Avatar
Thanks Guys! I am gonna go for it now!
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
GLOCKer
09-28-2015 07:36 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Rear spoiler help!
