Has my 'stang been reprogrammed?
Old 08-30-2008, 11:36 PM
Jasoon
Jasoon's Avatar
Default Has my 'stang been reprogrammed?
I'm the 3rd owner of a Black 2006 Mustang V6 Convertible, with the manual transmission. It is a blast to drive.
I've been reading that S197 Mustangs cannot add a cold air intake or an exhaust without having the computer reflashed. Yet, when I bought it it already had a CAI and Flowmaster exhaust on it. I didn't think about it at the time.
Or, is it just the GT's that have to be reprogrammed?
Thanks
Jasoon is offline
Old 08-31-2008, 12:43 AM
Lethaldosage423
Lethaldosage423's Avatar
Congrats on the stang,,,your going to love her..
the re flash it only to get ultimate performance out of her..right now you have horses that still want to be unleashed
http://bamachips.com/
read up on one of these tuners..not too pricey and everyone will tell you its worth it!
Lethaldosage423 is offline
Old 08-31-2008, 01:07 AM
So_Cali
So_Cali's Avatar
Not sure where you heard that but, yea getting a it tuned is definetly a MUST if you wanna unleash that hidden power in your car BAMA is one of the best out there in regards to tunes, Doug is the man for Tunes. I just got mine and I gotta say i dont know why I waited so damn long LOL
BTW, Welcome to the site bro! If your anything like the rest of us...Ur wallet is in for a hurting
So_Cali is offline
Old 08-31-2008, 01:13 AM
So_Cali
So_Cali's Avatar
Ooops double post, stupid slow internet LOL
So_Cali is offline
Old 08-31-2008, 12:16 PM
musicheadt
musicheadt's Avatar
JASOON,
The V-6'ers, as well as the GT (V-8's) CAN be re-flashed after a Cold Air intake install.
Post a link to some pictures of your intake......and we might be able to tell you if your car has an intake system that REQUIRES a custom tune. (some CAI systems don't REQUIRE a reflash).....others do.
musicheadt is offline
Old 09-01-2008, 11:11 AM
Jasoon
Jasoon's Avatar
Here's the air intake...
Jasoon is offline
Old 09-01-2008, 11:43 AM
157dB
Cut & Paste Expert
157dB's Avatar
Nope, thats a standard OEM intake tube with a heat dam and a high flow cone air filter.
It does not normally require a tune to keep from running lean. The previous owner
went for looks over performance. I would not suspect he dropped $400 for a tuner.
A real CAI with a roto-molded intake tube thats bigger than the OEM intake tube requires
a tune for proper MAF calibration so that the engine does not run lean.
Exhaust changes dont normally require a tune as the OEM exhaust is big enough
unless you go Forced Induction such as a blower.
157dB is offline
Old 09-01-2008, 11:52 AM
TAoW1939
TAoW1939's Avatar
Well then there is also the VMP intake which requires a tune, but does not replace the factory air tube. In fact if I recall properly, Justin at VMP compared the factory rubber tube and the C&L tube on a dyno and found no noticable increase in power.
TAoW1939 is offline
Old 09-01-2008, 12:12 PM
157dB
Cut & Paste Expert
157dB's Avatar
Rouch, I was wrong.
Is VMP comparing the V6 OEM intake tube or the GT intake tube?
Its the tubes size in the area of the placement of the OEM MAF sensor
that determines if a change of the A/F ratio is needed to compensate.
Or do they leave that parameter alone and just change timing and such?
157dB is offline
Old 09-01-2008, 01:45 PM
TAoW1939
TAoW1939's Avatar
The only thing that requires a tune is when a CAI alters the MAF housing size, once the air makes it through the filter and the MAF, tube size and construct is irrelevant.
TAoW1939 is offline
Quick Reply: Has my 'stang been reprogrammed?
