ph turbo radiator hose?
im not sure what you are asking.
the upper radiator hose is stock.
the stock lower radiator hose goes from the radiator to the pump, and has a T in it that goes to your coolant resivoir. the ph turbo setup does the same thing, but you are replacing a section of the rubber hose with metal.
ahhhh ok. thanks fazm. my reason being is that i was checking the killerglass website and wanted to see if i can incoporate that into the ph turbos radiator hose. im guessing it would be the top rubber part?
TfcCDR
09-14-2015 12:08 PM
