excessive fan running when tuned?
It shouldn't run all the time but running more often is typical so as too improve performance buy keeping the engine cooler. You can adjust the fan on temp with the SCT and I assume the Diablo. Check the low fan setting. No lower than 210* is probably what you want. Mine runs almost always if I set the low fan to 200*. It is annoying for sure so I only drop it at the track.
Also, is this a custom tune and if so which one and who's? Tuners typically drop the fan on temp so it may be set too low for your liking.
It's a Demolet tune on an Xcal 3. I'll run it past John when I request new tunes for the upcoming gear change. Just thought it was a bit strange, doesn't occur on my truck tunes, but they're just canned tunes.
HIS S-197
08-10-2015 05:47 PM
