8.8" axle swap - Fluid type/quantity?
Hey guys...
I'm getting ready for an 8.8" rear axle swap on my V6. I have the flange already. My question is, the axle comes without the fluid, so what do I need to buy? How much of it, viscosity? Do I also need a new panhard rod? for the install on my 05 V6? Or will all the other rear suspension parts fit right over? Thanks guys?
Hey guys...
No, you don't need a new panhard bar.. you have the flange; everything else fits.
But I'd go with what the service manual says I suppose.
Dude, who are you getting the axle from? I just had an 8.8" axle installed in my 05 V6 - I got mine from newtakeoff.com & it came with the fluid in it, so I'm surprised to read that yours comes without the fluid? Strange?!!
From what I understand if you have the stock cover the OEM panhard bar is fine, if you add an aftermarket cover then you may need to relocate or replace the panhard bar.
I would use the Motorcraft factory recommended, buy it from Ford.....when putting in the Friction Modifier from Ford use 1 and half to 2 Bottles of 4 oz. ......If you read around about 8.8's making moaning groaning sort of sound when making a sharp turn......some say TSB for clutch paks..."BS"......just needs more friction modifier, some insight from a Ford diff tech......mine was groaning added a more modifier sound was gone......just from experience use more than one 4oz. bottle of modifier........I used 2.....
Anyway if a 8.8 came with fluid inside, I would change it anyway.......IMO.
