How do you remove empty buttons from panel?
Is there any way to remove the little unused buttons that exist above the stereo? I am going to install a fuel flow readout in that location, and I'd like to run the OBD wire into my panel through a button hole.
If this makes no sense, give me a "WTF?" and I will clarify the question.
Kenny
Kenny
if you are talking about the 3 blank buttons that are for the cluster if you have it. take a small flat screwdriver and a piece of rubber ,cardboard or something to rest against the console and it pops out there is a tab on each side. just carefully slide the screwdriver in and it pry's out.
Those are the ones. What is behind the empty buttons? If I remove one, could I run a wire through the hole into my panel, down to the OBDII harness below the steering wheel?
Here's what I'm installing:
http://100mpg.ca/?p=163
jwog666
12-27-2021 08:09 PM
