Power for my stang
Power for my stang
Hey i want power out of my car but i can't afford to drop the turbo in it, what can i do til then to improve...i jsut installed pypes x-pipe and i love it, i'm think about a CAI from bama, and also heard about getting a new driveshaft, an 8.8 rear axle, and new gears...what do y'all think about this and if what are your recommendations...please send me some ideas on prices and the order i should be doing these upgrades...also links would help...THANKS
CAI + Tune would give you some power.
I dont think you should get the 8.8 rear axel if you dont plan on going FI, I would just get the T-Lok for the 7.5
You could also buy new underdrive pulleys, headers, ect... Just look around.
You need a tuner if you get a new rear end or gears to fix you're speedometer. I would go cai/tune next and if you have more money and want f/i in the future get an 8.8 rear with gears, no f/i get a t-lok and gears. Best bang for buck n/a mods are cai/tune, exhaust, and gears/lsd. After that would come Aluminum Driveshaft and that's $500 for less rotational mass and supposedly up to 2 tenths quicker in the 1/4 mile, and you can see your dollar/gains drops dramatically and even less after that. I'd say do those mods I listed and then save for f/i. Good Luck!
FI=Forced induction=Boost=Supercharger,Turbocharger,Nitrous
Depending on what forced induction you get, should determine what gears you get. Centrifugal type superchargers have max boost in the high rpms and work better(accelerate quicker) with higher numerical gears (3.73's, 3.90's, 4.10's, etc). Some centri chargers are Vortech, Procharger, and Paxton. Turbo you should definitely get 3.55 at the most. I think that's what Fazm is running with his turbo set-up and makes over 400rwhp. Roots type blower is a toss-up and makes a lot of low end power. Some people will say high gears are too much and others use them with the car and have no problems (beaustang=4.10s, x-charger and other mods). Roots is the x-charger.
If you get 3.31 gears you won't need a retune b/c that's the stock gear ratio. Other than that you will need a tune or a tuner to tell your computer the gear ratio on your car has changed so your speedometer is correct and your car runs fine.
