fang
fang
so how easy is it to paint the fang chin spoilers or does any body have/know were I can get one already painted black.
Also I want it to be flat black so should I put clear coat on it or do they make a matte clear coat or no clear coat
http://www.aeroformstore.com/2005-2009mustangfrontchinspoilerv6.aspx.
It's matte black, like the rocker panels on a stock V6 (or GT500)
Unless your planning on plowing snow in the morning with your new fang, I dont see why you'd feel that an overnight delivery is needed.
shipping a portion of a car bumper across the country in one evening isn't cheap. Try looking for the 5-7 day rate if you want to pay something reasonable for shipping.
Hope this helps.
negative, the fang comes in raw fiberglass, it's yellowish/tan in color. It's easy to paint though, i just used some duplicolor adhesion promotor, 3-4 coats of sandable primer, wetsand with some 600 grit sandpaper, and then I used krylon fusion's camouflage ultra flat black paint. i wouldn't get it painted professionally, because chances are you're going to have to paint it multiple times after it's been chipped up. I've painted mine 3 times and also had to fiberglass and bondo it after I broke it almost in half.
Hope this helps.
Hope this helps.
