The anxiety is killing me.
Bought the FRPP exhaust kit today, after having my GT bumper installed for a week now. The only thing I'm waiting on before I put it on is that I would like to use one of my friend's car lifts in their garage to lift my car up and make my life a ton easier. It's probably getting installed next week.
Anyone that has installed this kit on their Mustang that can give me any tips or advice on the install? Thanks.
As for tips: Get the car as high up off the ground as you can, and then just take your time with it. There will be some struggling probably, and you might say a few bad words, but it'll all fit together and you'll have the cool sound/look of duals in a few hours.
Take it for a run, then come home, crack a beer, and sit in the driveway ogling your Mustang's new booty.
Good luck!
As far as tips:
- have a zawsaw handy to cut the stock pipe ahead of the crossover
- the stock muffler will have an extra front rubber isolator/hanger (at the front of the muffler) that you dont need; simply unbolt it from the frame by its 2 bolts and remove it when you remove the stock muffler
- if you need to adjust the exiting tip locations, you can tweak the locations of the rear hangers by using some flat wahsers/spacers between the hanger and the frame; I had to do this to my STOCK side to get it to exit properly with different mufflers.
Also regarding your kit, is the pipes coming in suited for 2.25" pipe? The stock piping between the cats and Y are 2.25", and 2.5" after the Y. Hopefully your kit has proper clamps for making the transition. (I found this out the hard way when I first put my dual system on!)
BTW, doing the GT bumper is the way to go! I did a cutout on mine, but am looking for a rear bumper.
Good luck!
Good luck!
I'm sure I have all the necessary clamps, the kit came with around 8 of the things (they're all inside that white box to the right of the car in the first pic). I would have kept my v6 bumper, but somebody scraped the side of my bumper while I was at a stop. So with all the insurance covering the repair bill, I decided to pay an extra $5 and go with the GT bumper.
Thanks for all the advice! I'm going to need it .
1 more thing; on the instruction sheet, it says that I need to tap a hole for my muffler hanger on the left side of my car. But when I looked down there, there were already holes in place. Did you still have to make another hole to fit the hanger? Thanks.
The holes are already in place, but they aren't threaded on the driver's side.
However, I'm pretty sure the FRPP kit comes with self-tapping bolts so you should be fine. If they aren't self-tapping you'll have to tap the holes yourself, or just go out and buy self-tapping bolts for it.
I've also heard of a few people just forcing a normal bolt through so it cuts the threads as it goes, but if you screw those threads up you're going to be in for a headache and a delay in getting your exhaust done so I wouldn't risk that.
