[Problems, PLEASE help] Loud grinding noise and whistling noise..
Okay just to start off with the info of my car:
2007 non-PP Mustang, Automatic, Still under warranty, GT Single Muffer, JLT CAI w/ 91 bama race tune.
Okay, so a couple weird things are going on with my car and the idiotic stealership can't find a problem if they were smacked in the face with it.
Okay, so basically my car is experiences two weird problems.
1) After about 70mph, my car starts to whistle, like the sound of a tea kettle. This gets REALLY annoying at highway speeds.. I told the dealership and they claimed they took it out for a spin but they found "nothing"
2) In 4th gear, when O/D is off, when I accelerate and it runs through 2-3kish RPM there is a HUGE grinding sound! It isn't a light grinding sound it sounds like gears grinding and does not sound good/safe at all..
What do you guys think it could be?
Get the service manager in the car with you and reproduce the issues for him.
It is under warranty...let them sort it out. If they you show them the issue and they state it is normal, move on to another dealer.
Had the whistle before the CAI. The sounds feel like they coming from the rear.. can both be explained by the gears?
Just a thought and maybe not the issue at all but definately worth the try. Reflash your car back to stock tune....then, take it out and see if EITHER of those issues still happens. If they dont, then its the tune. Get a new tune from another tuner or just have your current tuner redo a tune for you. Like is said, might not be the issue but it takes 5 minutes to check. Oh, and you can always reflash your car back to your race tune if its not the problem.
I would go ahead and put the stock airbox on, reload your stock tune and do as I listed earlier and take the guy for a spin. Leave you number and do as UK mentioned.
You dont need to troubleshoot this...that is their problem.
