About to put it in new grill...
...and I was wondering if anyone had any words of wisdom before I go trashing my car like a numbskull. The kit is from "Mr. Bodykit" and is the "GT look" but MADE TO FIT THE V6. There are no instructions with the kit, but from what I can see, swapping out the grill is straightforward. My car already has the switch, wires and harnesses because it's got the Pony Package fogs already.
There is a plastic panel that covers the radiator, and that should pop off using a screwdriver to pry out the little pins. The grill tabs "should" bend sufficiently to allow the grill to just slide out. Am I missing anything here? BTW: For sale... Pony Package grille and fog lamps! PM me an offer... Ken |
Thats all, the tabs on the grille are very rigid and will seem as if they are going to break. The trick to use a screwdriver and a paint can opener. The tabs are black and behind them is a slot that looks like [ to get enough clearence to pop out the tabs; first use a screwdriver to lift the plastic piece, then carefully slide the end of the paint can opener under the [ piece. This should move the plastic tab of the BUMPER UP and allow you to PUSH the grill tab back and pop it out.
Sometimes the paint can opener wasn't enough alone to make enough room for the tab to come back enough to have enough room to clear the lip. To solve this i slid the screwdriver under the stock of the paint can opener to use it as a lever and allow more clearance for the tab to fully come back to pop out. this process is simple, just use enough force necessary and dont over do it, if it doesnt come at first try using the screwdriver. You may also need extra help for reaching the lower tabs because they are hard to do from the top, so someone underneath can help guide the screwdriver and paint can opener under the plastic tab on the bumper. |
Yeah the cover is held in by 'push pins'. Pry up the center pins, then if you can, just pull out the whole push-pin assembly, or wedge under it as mentioned above.
You put them back in opposite: make sure the pin part is pulled up, push in the round outer part, then push the pin down. For removing the grill, it might help to disconnect the grill where its center supports connect to the car; uses a 10mm screw. The grill is held in by tabs that stick up on the grill pieice. You have to push down the tab and push out the grill. Youll have to work one tab at a time and keep the other ones from working back in. Take your time and it will all come out. The first time you do it is a little tough until you figure out how it all goes together, then its a breeze. |
Originally Posted by tx_zstang
(Post 6012089)
You put them back in opposite: make sure the pin part is pulled up, push in the round outer part, then push the pin down. For removing the grill, it might help to disconnect the grill where its center supports connect to the car; uses a 10mm screw. The grill is held in by tabs that stick up on the grill pieice. You have to push down the tab and push out the grill. Youll have to work one tab at a time and keep the other ones from working back in. Take your time and it will all come out. The first time you do it is a little tough until you figure out how it all goes together, then its a breeze. I need to get the grill out as gently as possible, as I will be selling it as "excellent condition" and packing it into the box from my new one. When you say 10mm screw, do you mean screwdriver, or is there an actual screw that needs to be removed? Thank you! Ken |
Get some Pop Sickle Sticks Cut them up into 1 inch long parts then stick one into each slot over top the grill tabs then pull it out. Think about the new grill before you install it if the new grill will show any of the Bumper tabs more the the stock grill you may want to take this time to paint them Flat black before installing the replacement grill. Good Luck and have fun this is a easy mod to do.
5 Attachment(s)
Originally Posted by Ken Rogers
(Post 6012180)
Thanks, guys. As I tried to remove the plastic panel above my radiator, I managed to break the first push-pin I tried to remove. The center piece popped up easily, but when I tried to pry out the entire thing it just broke off.
I need to get the grill out as gently as possible, as I will be selling it as "excellent condition" and packing it into the box from my new one. When you say 10mm screw, do you mean screwdriver, or is there an actual screw that needs to be removed? Thank you! Ken Its a screw/bolt on the top of the bumper cover. The part that divides the grill from the headlight. The bolt(s) one per side are on the top. You can gain easy access from underneith, just avoid the A/C condensor fins. You might also want to take the time to black out the sheetmetal thats behind the grill while you have it out. :) |
1 Attachment(s)
Also check for proper fit with the rear of the fog lights and the sheetmetal.
Some cheap kits dont fit right and require bending of sheetmetal for clearance reasons. :( |
Originally Posted by 157db
(Post 6013831)
Some cheap kits dont fit right and require bending of sheetmetal for clearance reasons. :( Also, my horn is in the way. I have unscrewed it and moved it over to the right, but I will have to somehow extend the hanger so that the horn can sit farther over. Ken |
Horn? Unless they relocated it, it shouldnt be in the way of removing the grill.
(The idea of ice cream sticks is a good one! I will try that next time I remove mine.) |
(Post 6015407)
Unfortunately, I broke a tab during removal today. It's so cold out, the plastic just doesn't have much forgiveness. Should still fit solid for someone else to use, but I will likely have to come down on the price a little.
