the 2011 v6's have 8.8's in them but they also have 2.73 gears in them just did a gear in one on thursday with 286 miles on it lol and you can build a 7.5 to as much power as a v6 will ever make your just starting with less to being with
do you pound your 7.5 often? we heard you tearing up the alley behind afixer's house... lol. how has the X + 7.5 been treatin you?
I regularly pound my 7.5 and at 32K the axle bearings are starting to howl...
Bout to do a major teardown to replace the bearings.
Gonna check the gears for proper mesh and wear at the same time...
Does anyone know what a gear swap on a 2011 V6 from stock 273 to 3.55 would/should ~ cost...ring and pinion gear set, labor and positive traction rear gear oil? Also a AL drive shaft at same time
