CAI tune that will pass emissions w/o making changes?
I know this has been posted before, but I was wondering if anybody has a combo that will pass emissions in Mass.
I just got this 4.0L mustang a few months ago and am thinking about CAI/tune, 4.10 gearing, Tlock, and short shift kit, but I don't feel like reflashing or removing anything just for inspection.
I was thinking about the BBK because it is able to run with factory settings; therefore one may just reflash to stock without removing the CAI for an emissions test.
What is the purpose for disabling the emissions sensors on the tunes anyways?
honestly i dont think any tune will have a negative effect to the point where u wont pass smog. But if u want a CAI without a Tune then the bbk one is good... thats wat i have... and i'm pretty sure if i can pass emissions in CA then u should be able to in MA
I don't know the specifics of the tunes, but I have read many times that some sensors are disabled and that's it won't pass.
I guess I am wondering several things,
Can you safely run BBK CAI on higher octane without a tune without any adverse effects? I know that BBK says you can but I have read otherwise. Anybody experts know?
And
Is there a tune for this car with a CAI that is customized to the CAI and will pass when they hook up to your computer?
And
You cant just return it to stock tune? Or some economy tune? Wouldn't an economy tune be better for the environment and stuff since it gets you better MPG?
(Sorry I'm unfamiliar with these tests -- MN doesn't require any testing at all.)
I think that is what I'm trying to figure out maxshuty. I don't really want to have to remove the CAI once I put it on. I guess its not that bad to have to put the stock stuff back on but it would be easier if I could do nothing. The next best thing would be if I could flash it to stock without removing the CAI.
And
And
Turning off the rear 02 like most tuners do will have nothing to do with passing emissions in most states which are measuring the actual exhaust emitted not what a sensor says is going on with emissions. If your cats are still there I can't see why there would be an issue. If that were the case where inspections stations hooked up a line to your ecu to read the car's interpretation of the emissions every tuner would just write a tune that made a Mustang look like a Prius.
You will be fine as long as your cats are there. If you get a tune flash it back to stock to take it to an emissions place. Its really not that much of a hassle.
Most tunes turn off the rear O2 sensors so with the new emissions test in MA the computer will read the PCM in the car as not ready with the sensors turned off. You can swap back to stock and run for about 50 miles and then test or ask your tuner to write the tune so it does not turn off the rear sensors. Either way and you should pass.
