Gear Install Checklist
Planning to throw on some 3.73s in the near future and just need a rundown on what I'm gonna need in order to do this. I know the 2 most important things of course.
http://www.evoperform.com/shop/index...ac752cf9b0287e
And of course a T-Lok
http://www.americanmuscle.com/ford-28spline-75-lsd.html
What else am I gonna need? Thanks in advance
Gear install kit, with carrier and pinion bearings, ring gear bolts, shims, loctite, crush sleeve, silicon for rear cover, etc.
And of course, 2 bottles of rear end fluid, and 4 oz. of friction modifier.
Hopefully you have someone to do this or know how to do it properly; it takes some special tools to do everything right or at least it really helps to have them (mainly a press for the bearings, proper-size bearing race drivers, dial gauge for measuring backlash, an inch-pound torque wrench for pinion preload).
Yea, this guy specializes in Gears/Differentials and is ASE certified. He's done 4.10s on a buddys Stang. Can you point me in the right direction of where to get the aforementioned kit? Where did you get yous Tx?
I've put in a few different kits, and got them from different places based on pricing at the time. One was american musle, that was for a 7.5 kit. I got the 8.8 kit from somewhere else. Prices vary A LOT, even week to week on the same site. Just shop around and get the kit that has what you need. I prefer the kits with Timken bearings, but the Toyo (?) ones are ok too, as that's what is stock in the 7.5s if I recall.
Sad thing is, I dont think I'll get blown anytime soon so a 7.5 is suffiecient enough for what I use my car for. Now, are the gears I posted legit? I heard about the "M" being for Motives which have gotten mixed reviews on here. I wanna do this right the first time and just wanna get my facts straight...
I Guess these are the same gear install kit, one of the says Timken tho. Which should I get? I just hit 60K miles
I found a Timken one
http://www.northernautoparts.com/Pro...tModelId=12648
And the Motive one
http://www.americanmuscle.com/rearendrebuild1.html
Also, what type of gear oil do I need?
And the Motive one
Let me see if I can offer and help, as I have 3.73s in my trunk, going for installation this weekend!
Gears you posted... "M" from what I have read mean Motive made. To my knowledge and extensive research, Ford no longer makes 3.73s for the 7.5 rear as FRPP. When Ford DID offer them, cost was about $289, quite a bit more than the Motives. Thus, I settled on the Motives from AM - and a little cheaper than what you had posted. Mixed reviews on the Motive brand gears - will have to wait and see (confident in my Ford 20+ years mechanic for the install).
http://www.americanmuscle.com/mopepl3gefor.html
T-lok - you can find that cheaper here, or contact AM and they will match the price (I like dealing with AM)
http://www.stangmods.com/V6-Mustang-...1-m4204c75.htm
And the install kit of course...
And some oil...
http://www.americanmuscle.com/royalp...0-gearoil.html
I got my setup for $410, plus a deal on the install - make it much cheaper, although not as easy, as a new 8.8 with gears already there. I don't have any plans on going F/I either, so I am good with the 7.5.
And some oil...
And some oil...
And some oil...
