Ok just one other question...
I've been asking about different mods and trying to learn and understand all these things. After talking on here and around let's say for argument sake I go with the Ford V6 duel exhaust kit like this one http://cgi.ebay.com/ebaymotors/ws/eB...lenotsupported
Ok my next question is related to headers, I was planning on maybe changing out my headers to go with the new exhaust. Which kind work? Shorties? Long tube? which would fit
thanks
thanks
What did you wanna know about the kit?
As for headers you can check out Stainless Steel Works for some longtubes, not sure if they'll fit that particular exhaust. JBA and I believe Pypes make shorties for our 6ers
Thanks
Headers aren't really worth it in my opinion unless you go F/I (Forced Induction, ie supercharger). They cost a good chunk of change for small gains.
I think since you are new to modding, you will be MUCH better off getting gears/t-lok than headers. You will definitely notice a different there.
You currently have a 3.31:1 gear ratio. Which means your driveshaft will turn 3.31 times everytime your tire makes 1 full rotation. Going to a lower gear ratio (which means a higher number such as 3.73 or 4.10's) will give you more off the line performance.
I have 3.73 gears so I have alot of punch off the line. The reccomended gears for our cars are 3.73 or 4.10. If you plan to go with a supercharger or turbo.. 3.73 will work great.
A T-Lok or LSD (Limited Slip Differential) will change the traction of your rear end. Our V6 Mustangs come with an open differential, which means only 1 tires spins. The power is usually thrown to 1 tires, where as a T-Lok makes both tires spin, so giving you traction to both tires at the same time.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
Also I was looking at this http://www.americanmuscle.com/ford-28spline-75-lsd.html
