Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: How to Install H-Pipe
Step by step instructions for do-it-yourself repairs.
GT H pipe on V6?
that being said if you just buy and x pipe from pypes its just a cut and bolt on deal.
Aftermarket headers maybe, but not stock ones.
Ok that is exactly the answer I was looking for. Also, here is a link to NAPA that sells over axle pipes. I don't know if the one here is for the driver's side or if it doesn't matter, but I thought I'd throw it out there for anyone interested and maybe someone can clarify.
http://www.napaonline.com/masterpage...e+Exhaust+Pipe
yeah thats the answer you wanted but its not right. think about it the v-6 and the v8 are totally different physical sizes nothing is going to line up without cutting. I know I've done this. The pipe from napa is the passenger side which is the same for the v6 or the v8 I tried to go that route also. I just picked up a used drivers side from a gt at enghlishtown swap meet. All in all you would be money ahead and much easier just unbolt your v-6 muffler bolt on a single gt take off and call it a day. sounds just as good as duals and only take about 30 min tops to put on. then later on if you must have duals for looks get a kit cause if yo paying somebody to do all this its not worth it.
