Shaker 500 Rattling Noise
Ok so i have the shaker 500 system and when my music is playing the bass shakes the car like i love.But the power window switches on the drivers side rattle. Making an annoying rattling noise when the music is playing. If i put my fingers on both switches, the rattling goes away. I took it to best buy when i was getting my alarm fixed and asked for advice and they said because the rattling was comming from the switches and not the actual door panel, theres nothing i could realy do... any advice?
I had a rattle in my drivers side door except it happened constantly between 2300-3500 rpms because of how low my exhaust is. I told the guys that tinted my windows this and to watch out and see if anythings loose. I watched them tint my windows and install moleskin (they took the door panels off) and they didn't change anything but after they were done the rattle was gone. I'm afraid it might be starting to come back though... I don't know where mine came from and I don't think it stopped when I pushed on the window switches. Maybe ford forgot to put something soft between two plastic pieces???
It's not the switches. It's the switch housing. Take out the armrest panel containing the window switches, and you'll see that the entire switch housing - not just the switches - rattles around inside the arm rest panel. Remove the switch housing, stick some Dynamat to all sides contacting the armrest panel, and reinstall the whole thing. Should take less than five minutes.
Hmmmmm.
Google search JEGS DYNAMAT??
http://www.jegs.com/p/Dynamat/Dynama...63880/10002/-1
It cost as much as its worth.
This is a very common problem with our stangs. I had it in mine too. Google TSB 07-17-6 and you'll find all the info you need. If you're under warranty like I was the dealer will fix it for free. You can also DIY
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Ghost_Conscience
09-23-2015 02:17 PM
