External Sirius Wiring Question--Radio Delay
Old 07-10-2009, 06:37 AM
WVPony
WVPony's Avatar
Default External Sirius Wiring Question--Radio Delay
I've installed a external Sirius Starmate 5 in my car. It sits nicely below the AC controls--held in place w/ velcro and wires hidden via loom.
When I first wired it it was on constantly even when car was off. So I wired it to a "switched power" fuse in passenger side box. So now it turns off when the car is turned off. Only problem is that the Ford radio delay keeps the radio on until the door is opened but the Sirius goes off as soon as the key is switched off so I have static until I open the door.
Does anyone know how I can rewire the Sirius power wire to a fuse (or something?) so that it stays on when the key is turned off? That way I'd have satellite sound until the door was opened. My Explorer works like that but it was professionally installed and I don't know how they did it.
Thanks!
WVPony is offline
Old 07-10-2009, 07:31 AM
gmchx4
Do you have a sub and/or amp in your car? When I had my satelite radio I had it spliced in with my amp so that it was on only when the car was started and remained on till the door opened.
I am pretty sure I have my amp running through my head unit power supply to acheive the same thing for it, but I cant remember if that was how I did this car or my last, its been years since i installed this system. (if you don't have an amp just look into the head unit power supply for a spot to cut in)
Before the mustang I had a Jeep. I installed an off-road light bar on it and wired it through the ignition switch. This allowed the lights to only be on when the car was running (so funny friends wouldnt drain my battery while I was in class), but im not sure if they remained on if the car was turned off and the door was still closed (i ran without doors all the time and removed the light/buzzer switch from the door jam, so there are a couple of outside factors in this scenario that may have affected why the lights did/didn't run with the door closed and key off). They ran as long as the key was in, but I think once it was removed they shut off; however, I don't know if the Ford ignition is the same as Jeep so maybe it would work
just a few ideas to look into, good luck ...
gmchx4 is offline
Old 07-10-2009, 08:16 AM
157dB
Cut & Paste Expert
157dB's Avatar
Thanks!
Simple pimple.
Let me get the wiring diagrams out and I will find the DACC (delayed accessory) connection point.
It might be as easy as a tap a fuse in the proper location on the SJB...
The online wiring diagrams really dont show the power distribution I need to see.....
EDIT: FUSE 6 in the SJB.
Tap a fuse for the win.
Be sure and follow the tap a fuse instructions to the T...
157dB is offline
Old 07-19-2009, 07:51 AM
WVPony
WVPony's Avatar
Thanks guys. I'll give it a try. I think the window fuse tie-in will do it since they are on the delay.
WVPony is offline
Old 07-20-2009, 10:46 AM
Xargon321
you can also try taping the Dacc wire going into the back of the radio. use a relay to shut down the main power to the siruis unit when the door is opened just like the radio does now
Xargon321 is offline
Old 07-20-2009, 10:49 AM
157dB
Cut & Paste Expert
157dB's Avatar
Bad idea.
The power window fuse is not DACC controlled.
Its hot 24/7 also.
Try my suggestion as it works, no guessing.
Geeze, lead a man to water and he will not drink.....
157dB is offline
Old 09-12-2009, 05:48 PM
WVPony
WVPony's Avatar
Default It works now!
Well, I got it working just fine. I connected the Sirius Power to Fuse #6--labeled "Accessory Delay" in the manual. Works great. Radio AND external Sirius stay on after I turn the key off until I open the door. Thanks for all the suggstions. (Some of the suggestions were a bit confusing to me, so I thought I'd write back to say what worked for me in a simple way. Some of you guys presume we know more than we do with your rather technical suggestions--I'm sure a lot of us aren't very technically inclined. Thanks for all suggstions!!!!)
WVPony is offline
jwog666
01-07-2018 07:16 AM
rgingo
Forum Issues and Feedback
10-21-2015 12:49 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
Quick Reply: External Sirius Wiring Question--Radio Delay
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
