Old 10-20-2015, 10:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
My brake lights don't work
Old 07-17-2009, 09:34 PM
johnnyv
johnnyv's Avatar
Default My brake lights don't work
Hello all,
This is my first post, so I apologize if I didn't post in the right place.
I have a 2006 Mustang. The problem I'm having is that my passenger side brake lights don't come on when I step on the brake; however, they do light up when my headlights are on. Passenger side blinkers don't work either. I checked the fuses inside the car and they are all good. Any ideas?
Thank you
johnnyv is offline
Old 07-17-2009, 10:56 PM
JCON
JCON's Avatar
I haven't even checked my bulbs since I got them but I think they are dual wattage/filament bulbs. one of your filaments (oddly in both bulbs) may have burned out. get some new bulbs and try that.
JCON is offline
Old 07-18-2009, 09:15 AM
157dB
Cut & Paste Expert
157dB's Avatar
Wet SmartJunctionBox syndrom.
Search 'water leak' in the S197 section of the forum and thats your answer.
157dB is offline
Old 07-18-2009, 09:30 AM
SixN2
SixN2's Avatar
Are both the front and rear passenger side turn signals not working? Does the turn signal lamp in your dash operate rapidly when you turn the passenger side on, does it come on steady, or does it not light at all?
SixN2 is offline
Old 07-18-2009, 12:05 PM
johnnyv
johnnyv's Avatar
Thanks guys.
I checked this thread https://mustangforums.com/forum/4-0l...t-problem.html
I thought it had something to do with "wet". I had something spill in my trunk on the passenger side right behind the taillight. I also had a problem with the wipers coming on on their own after a heavy rain. I took it to Ford and they couldn't find the problem. My warranty just expired last month, so I'm SOL on this one. Any suggestions on how to fix this on the cheap?
Side note: My mother is suing Ford because Ford lost (yes, LOST) her car while they were doing some repairs; I wonder if I can persuade the dealership to work on my car for free to avoid a class action lawsuit considering how many Mustangs have this problem. Last year I had to take my car in for body work because the hood was corroded (something common in 05-09 Mustangs)
johnnyv is offline
Old 07-18-2009, 12:26 PM
157dB
Cut & Paste Expert
157dB's Avatar
The SJB is not in the trunk and your 'spill' has
nothing to do with your electrical problems.
The SJB is on the pass side kick panel.
Check your carpet for signs of water or mold.
It cant be fixed cheap. Too bad its not under warranty.
https://mustangforums.com/forum/sear...earchid=954918
157dB is offline
Old 07-19-2009, 03:41 PM
johnnyv
johnnyv's Avatar
So I checked the SJB and everything looked fine. Then I decided to switch the passenger side taillights to the driver side. They didn't work, switched the driver side taillights to the passenger side and worked perfect. Hmm... wiring harness gone bad? Switched everything back, and put the stock wiring harness back on, and now I have two working lights on the passenger side. I assume that one of the bulbs went out in the switching mess. I'll replace it tomorrow because it's raining like crazy today.
Definitely glad it's not a SJB problem; I wonder if replacing the bulb will allow me to put the sequential taillights back on. I'll find out tomorrow
johnnyv is offline
Old 07-20-2009, 06:32 AM
28HopUp
MF Administrator
28HopUp's Avatar
Didn't know you had sequentials. With most (if not all) sequential taillight kits, if the inside (1st) bulb burns out then none of them will light up on that side. (think of a series circuit). Replace the bulb(s) and you should be fine. My S197's would go through taillight bulbs like crazy.
28HopUp is offline
Old 07-20-2009, 10:53 AM
157dB
Cut & Paste Expert
157dB's Avatar
The SJB controls each filiment with a seperate wire
for bulb monitoring purposes. I would suspect bad
SJB before bad wiring harness.
Check for the proper voltages on the proper wires
at the SJB to rule out a bad wiring harness.
Go buy a good test light and use the online
service manual.
StopLight diagnosis procedures just like Ford would use...
157dB is offline
Old 05-10-2013, 04:16 PM
poney_girl91
poney_girl91's Avatar
Hey, I have a 2000 Mustang and my driver side lights are doing the very same thing, but I dont know what it could be. I pulled fuses and tried new bulbs. I NEED my car running asap. Does anyone know whats causing this yet?
poney_girl91 is offline
Quick Reply: My brake lights don't work
