TCI ratchet shifter & Morosso tanks
So I got my TCI ratchet shifter and installed it. I gotta say it is better than I expected. The install was not as easy as they claimed it to be (unless you have access to a lift). But the quality is excellent, it seems alot better than the stock shifter for sure.
It is also alot of fun to play around with, although it doesn't seem to let you downshift as easily (unless I did something wrong).
Here are some pictures of it installed, along with my coolant expansion tank and power steering tank also
No, there wouldn't be a difference in an auto shifting manually or a manual shifting car. It isn't as efficient, for the track you want it in drive and leave it.
Avalanch3: Before I swapped out the shifter I could downshift no issues, but with this shifter it seems like if I am too high on rpm's it won't downshift.
I would like to insure that your ratchet shift is operating properly. If you can please email, pm or call me when you get a chance. Thank you for choosing TCI products.
Thanks
Russ
junior04
09-28-2015 10:53 AM
