how wide a tire will fit on a s197
Old 10-01-2009, 10:16 PM
Jebmustangv6
Jebmustangv6's Avatar
Default how wide a tire will fit on a s197
Iam looking at new rear tires. I am looking at 295/45r18 or 305/35r18. my car came with 235/50-18 on the 2010 18" wheels stock. Could I tuck either of these size tires under the stock 2009 v6 stangs rear? thanks Jeff
Jebmustangv6 is offline
Old 10-02-2009, 07:21 AM
jtstakelin
jtstakelin's Avatar
You can put 315's in the rear is you want.
jtstakelin is offline
Old 10-02-2009, 07:42 AM
Nuke
Nuke's Avatar
It depends on the wheel width and offset. If the stock wheels are 8.5" wide, the widest RECOMMENDED tire is a 255 for that size rim (in most cases).
Check the tire specs for various brands and models of tires on sites such as tirerack.com to see what the wheel widths are for various tires.
Nuke is offline
Old 10-02-2009, 08:01 AM
ODDYSEY
Site Moderator of Fury!
ODDYSEY's Avatar
I am running 18x9 with a 24mm offset in the rear, and I have them wrapped in 285/40 R18. They stick out past the fender a bit, but look really aggressive and great.
ODDYSEY is offline
Old 10-02-2009, 03:39 PM
157dB
Cut & Paste Expert
157dB's Avatar
I have seen 275/40-18s recommended for 8.5" wide rims.
I went the wrong route with the 255/45-18s on 8.5" wide rims.
The rim width and offset determines the widest tire you can cram under there.
Give us the rim info and a recommendation can be made from there...
157dB is offline
Old 10-03-2009, 01:25 AM
Jebmustangv6
the car came with 235X50-18" s on the same wheels they are putting on the 2010 GT it is a 09 45th AV edition.
Old 10-03-2009, 08:43 AM
157dB
Cut & Paste Expert
157dB's Avatar
Please enlighten us with the OEM widths of the new 2010s rim packages...
Or a Ford part # for said rim so it can at least be googled...
Help us help you...
157dB is offline
Old 10-03-2009, 01:20 PM
shb5007
shb5007's Avatar
I have 325's.
shb5007 is offline
Old 10-03-2009, 01:52 PM
howarmat
s197 Junkie
howarmat's Avatar
Damn that is going to slow the car down! lol
howarmat is offline
Old 10-03-2009, 02:17 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Matt, if you install door moldings, it makes up for it...
pascal is offline
Quick Reply: how wide a tire will fit on a s197
