Just picked up a set of Roush Rear Shocks, got a question..
So I just picked up a set of rear shocks off of a Stage 3 Roush (They are not the blue ones like from the stage 2, they are the red ones off a stage 3).
So I also picked up a set (all 4) of lowering springs from ground force. Lowers about 1.1 inch front, 1.3 in the back, so not too much.
I want to just install the rear components for now (Roush shocks and rear lowering springs) since my front struts are OEM. I have three questions now:
1) If I just replace the back components, will it make my cornering unstable because the front ones are unchanged?
2) When I change the front struts, I can't find a set of Stage 3 Roush struts because no one sells them. I looked at the stage 2 roush struts but they seem wayy too expensive. I looked at Steeda's non adjustable front struts, but will two different company shocks and struts make them not work at their full potential?
If you were to install only the rear parts and the car has quite a few miles on it, you may be in for a slightly pitchy ride, with the rear feeling fairly well planted down and the front feeling like it's bobbing up/down more than you're accustomed to.
3) Will it be too stiff if with this setup?
Norm
Thanks Norm, very good explanation.
Odyssey - The reason why I am not going with Tokico is because if I went with them, I would need the D-Specs and they usually are sold as a kit. Each front strut is sold $200 separately and that is a bit too pricey.
I decided to wait to put anything on until I get the front Struts from Roush. The stage 2 ones will do because both are "race inspired" so I do not see much of a problem.
After this I am ordering myself some new shoes, some Falken 452 tires since my OEM ones are crap.
