black window trim fading
I'm surprised no one has mentioned Armor All. It's probably the cheapest alternative and makes you black plastics look great. The best part is that when it rains it is water soluble so it leaves no residue on your paint. I use it on my tires also since I don't want all that black stuff on my fenders. When I bought the car they threw that back to black stuff on my tires. A week of driving later I thought I had tar all over my fenders, but it was that black stuff and it just wiped off.
It attracts dust and it actually DRIES OUT the plastic
causing you to have to re-apply it over and over and once
you use it or the plastic looks even worse than before you
used ArmourAll. The more you use, the more you need to use
to regain the black appearance. The company designed it that way.
Imagine that....
And the fact that its water soulable means it has
no place on the outside of a vehicle besides not
using it ever on the inside of a vehicle.
Its the cheapest for a reason.
Time will tell and it has told me a lot.
In fact they dont even sell it anymore around here.
I think the product has been discontinued by the manufacturer.
So its a big no on the ArmourAll. I know what its made of....
btw... Back to Black states to not use it on tires on the container
tire shine is for that if you must
My black mirrors were discoloring and at a car show another stang owner told me how he uses the Meguiar's product because his mirrors were doing the same thing. I've been using it and love it - turned my mirrors and all the other plastic/rubber pieces around the car back to black!!
http://www.meguiarsdirect.com/produc...?T1=MEG+G13616
Edit: I know it says it's the interior detail but I've been using both in and outside the car. No problems at all and it's not greasy feeling either. I like it a lot.
Plastics are one of the biggest problems Ford has. That is one reason I really don't like all the lower body plastics on the new Mustangs. I'm certain that in a short amount of time they will turn ugly. Then it's up to the owner to paint them or constantly keep adding stuff to make it look good. If you need examples of what I mean, just look at the Expeditions lower trim pieces, they all turn ugly.
I used to use STP Son of a gun on many vehicles for years and never had a problem with cracking or discoloration. They recently discontinued that product and I started using Armor All. I really didn't like that too much because it tends to dry unevenly, and recently I started using an Turtle Wax product that is less greasy and gives a nice smell to your interior. If after a while I don't like that I may try the Maguires. A lot of these products are made for interior but they can be used on the exterior with no problem, the only thing is that they will wear off with water. In you are in the West where it hardly rains, then that really is not an issue.
I've also tried Aerospace 303. I find it is a good product, a little pricey but it doesn't attract dirt and dust as bad as some other products.
I'll have to try the McGuire's interior stuff on the trim.
Do your wax deed and remove the tape.
DONE.
07 Stang, Turtle wax is for paint...
Sandman must be using something else.
