very confused
Although not as common on the '07's and up, the S197 suffers from a water leak into the passenger kick panel where the Smart Junction BOX (SJB) is located. If not corrected and attended to, the dampness will eventually corrode connections to the SJB and result in all kinds of gremlims. Assuming THAT'S your problem, of course, then the remedy is to clean all of the connections.
Its the galvanic corrosion thats sets up on the SJB circuit board.
The copper traces are turned into a white powder.
A simple 'connector cleaning' wont suffice, Nuke.
Thanks, 157db. Since I haven't had the issue myself I wasn't aware of this and made a WAG assumption.
What IS the proper method of cleaning the SJB? Or are we S.O.L. and need a new board? Perspiring minds want to know...
i guess ill be checking this today when i get home
now im worried bc i just realized that recently my dash has been reading a tire pressure monitor fault randomly then turning itself off after a bit
hopefully nothing else starts showing up....
YOU ARE ON YOUR WAY TO CORROSION.
ok well i checked out the passenger side and no wetness or mold
even took a look at the box and felt around and didnt feel any dampness or anything
so i think it might just be the battery
im hoping the tire monitor fault is a result of the tune bc it appeared teh 1st time after i started the car after loading the tune
mrappe
09-26-2015 10:16 AM
mungodrums
09-22-2015 08:36 PM
