evrything needed to lower my stang???
thanks kn0x. your drop looks good. did you get the struts and the other things needed for the drop? so basically from the parts u guys have been telling me. a drop is going to run me around 1000 with install out the door?
Tama: If you can do any work on your car yourself, you will save a lot of money. Here is what I did with mine.
FRPP N Springs - $200ish
Tokico D-Specs - $500ish (you can get less expensive Tokico HP's for like $360)
BMR adj. panhard - $125ish
Camber bolts - $35ish
I did the install myself on everything, and then took the car in to get an alignment when I was done. You can just install springs, but after a few months your stock shocks/struts will start to get bouncy and you won't like that.
you will still need a camber bolt and maybe a PHB. Your stock dampers wont last long also if you dont replace them with any springs and then you are paying double labor/alignment, do dampers with springs always.
To all the people that have the 1.5 or greater drop, do you have problems scrapping in your driveway? I dont if its just my driveway but I couldnt even go down it straight at stock height.
