evrything needed to lower my stang???
Old 01-05-2010, 10:10 PM
tamazulense
tamazulense's Avatar
Default evrything needed to lower my stang???
going to lower my stang but need all the parts and information needed. want to know whats the total price out the door going to be around. from the parts to installation prices. i want decent to good springs not no cheap ones. and also whats the best drop in inches for my car in looks and in performance.
tamazulense is offline
Old 01-06-2010, 08:57 AM
ODDYSEY
Site Moderator of Fury!
ODDYSEY's Avatar
I went with the FRPP N Springs (1.25" - 1.5" drop) $200 bucks.
I also went with Tokico d-specs struts/shocks - $500 bucks.
Not counting install.
ODDYSEY is offline
Old 01-06-2010, 06:39 PM
legendlime05
legendlime05's Avatar
if you go over an inch, youll need a adjst. panhard bar. your oem shocks and struts wont last a long time with the drop. so if the wallet allows it get them also. the cost all depends on what parts you get and if you want to do it right.
legendlime05 is offline
Old 01-06-2010, 07:28 PM
2010V6Stang
BEWARE! Possible Scammer
2010V6Stang's Avatar
Contact Sam Strano..... He will hook you up.
2010V6Stang is offline
Old 01-07-2010, 03:43 AM
tamazulense
so its not as simple as getting springs and thats it. ur saying over an inch i need struts as well. and bout adjusting the panhard..u mean getting a new one or the factory one can be fixed.
Old 01-07-2010, 09:06 AM
2010V6Stang
I am going with steeda sports which is an inch in fornt and 1.5 outback, I would even need new struts (which I got, KONI STR.R). You will also need some sort of camber adjustment so everything is in alignment and you dont wear out your tires. Also I got a double adjustable PHB, the factory one cant be fixed. Contact Sam.
Old 01-07-2010, 12:26 PM
legendlime05
sam is very good with details and the right setup for you. but camber bolts are an easy fix. youll need a new panhard if you go over an inch. your stock dampers wont last with a drop over time. our stock damper suck.
Old 01-07-2010, 04:00 PM
tamazulense
is sam strano a member on here?
Old 01-07-2010, 07:17 PM
legendlime05
he sure is just got the handling section. hes everywhere there.
Old 01-07-2010, 07:26 PM
2010V6Stang
or go to his website..... stranoparts.com
Quick Reply: evrything needed to lower my stang???
