What Type of Fuel to Use?
I keep the tuner in my trunk since I run an 89 octane tune and I travel a lot. I've had a few instances where I was near-empty and couldn't get anything besides 87 octane. I loaded the 87 tune and was back on the road in minutes.
The tech at my dealership told me NOT to run anything higher octane than 87. The injectors are computer tuned to run that octane and the V6 will not retune itself if you put a higher octane gasoline in the thank. The higher octane may even create premature wear and tear on the emission system. Also, higher octane fuels don't have more detergents than lower octane fules from the same company. Just buy a quality rated 87 octane and you'll be fine. Anything else wastes money on the V6. Of course, all that changes if you get a special tune.
just run the 87, unless tuned. Then run whatever octane fuel your tune is written for. When ordering tunes, you usually get 3 tunes. Get one for the 87, and 1 or 2 for the premium. That way, as mentioned, if traveling and you need to switch fuels you can. Or if you're short on cash you can switch.
Your engine is probably pulling timing because of detonation with 87. Are you running a stock tune?
I have never used Seafoam or any other type of gas additives and haven't had any problems with using BP's regular gas. I do get regular oil changes and other maintenance done on a regular schedule.
Once in a while I'll use either Sam's Club or Costco gas and the car still runs fine.
Whether its true or not, I've always been told to try to use fuel from the same place. Better for your car.
I always run 91 no elthenol, I am tuned for the 91 octane as well. I have heard a lot of reveiws saying ethenol isn't great for your engine.
Yeah but what are going to do when all the gas stations you normally get gas from uses 10% Ethanol?
The added alcohol in ethenol gas supposidly dries out seals, O rings, gaskets, and hoses faster than straight gas. My tune isn't written specifically for ethenol free, so I can use it if I choose. I do think that my car runs better on ethenol free though.
For the past few years, with these higher tech engines with electroinics, I strickly use TIER ONE gasoline and if manual calls for 87 Octane usage, that is what I fill up with. I also throw in a can of Sea Foam every 25,000 miles or so. Works for me with no engine performance issues with our vehicles and know my injectors and valves will always be spotless. I always keep a copy of Tier One gas manufactures in our glove boxes.
