tire size question
tire size question
I found someone that is wanting to sell me his tires that have 98% tread life left and they where mounted on 9" wide rims, i told him mine where 8.5" wide, and he said they would still work... is this true?
yep, you can use up to a 255 series on stock 8.5" rims. I've even seen 275's but they bulged a little.
What size are these tires that have the boos
koos of tire tread left?
Needed info for an answer...
I have 255s on 8.5" wide and plan on going 275 next time.
Bulgers corner like sheit...
Not enough information. What size are the tires? Not just the width - you need to supply the aspect ratio as well. And actual tire dimensions will vary slightly between different tire manufacturers, even tho the stated size is the same (perhaps moreso with drag radials than street tires). Check the tire manufacturer's website to see what rim size they recommend for that size tire.
The OP has a 2008, so the stock 17" rim width is 8", not 8.5". He must have aftermarket rims. I forget the width on the 16" rims, but I don't think he has those on his car if he said the (aftermarket) rim is 8.5" wide.
your just chiming in for all my threads haha, so would 275 /55 /20" fit my 20X8.5" and would it look good?
