V6 motor build help!!
I got the link from someone on here but can't remember who. I only want the x-charger if I go that route cause I don't like centri style it will cost around 3000 for all that's not minus any core charges I get back
What exactly are you trying to build and what kind of numbers you looking for?
Doing the cams will be a challenge, as the timing chain on the passenger side is at the back of the motor. The ford service manual lists several special alignment tools that you can probably pick up for a decent price used (ebay or on some forum), and I'd recommend getting them.
Just put a blower on and use stock heads/cams, and you'll have 300+ hp.
yes, supersix does make cams, i posted here about a month ago when i found out they supply them again, il look to see if i can find my old thread. they also have a higher duration so the new cams will have a better sound.
I knew I heard from someone that they found a new vendor for cams on here!
