Door Switches messing up
Ok my driver side door switch I believe is going and I am trying to confirm this. The auto down feature works just great a simple tap and both windows go down. As for going up the passanger side switch on the driver side door works just fine for auto up as well, but the auto up on the driver side for the drivers side I have to hold till the window is halfway up and sometime it doesnt even work. it hasnt done this till today but has done it all day. Anyone else had this problem
Hold switch down.....the window will roll down.......keep holding the switch like 5 seconds and then go up holding the switch up for like 5 seconds....it will reset the window.....that may help.....it is in the manual somewhere.....
I would suspect the auto switch contact is out or
the logic on the window motor is bad.
The actual motor has the electronics
for the short drop, up, down, auto up and auto down.
Pull the switch and jump the auto up wire
(Violet Lite Green - drivers auto up) to 12 volts
with the up switch manually activated.
Or tap into the violet/lite green wire with a test light to
see if it is sending 12 volts to the auto up on the motor
logic board on the motor.
breaking
10-02-2015 01:27 PM
09-25-2015 06:58 PM
