Transmission Problem?
I just bought my 07 V6 in Feb 2010. The clutch was really stiff, but I was told that's how it is. In about August-Sept, I would shift gears and the rpms would increase and the engine would rev up, but I guess the clutch was slipping. I would have to let off of the gas and slowely increase speed. I replaced my clutch with a centerforce DF in Sept (I think). It was fixed and no problems until now.
It's starting to do the same thing again. The worst gear is 4th. I'll switch gears at about 3000-3500 rpms and it shoots up to 4000-4500 but I don't increase speed until I let off a little and press the gas lightly.
A brand new clutch can't go out in 3-4 months, can it? Is this my transmission? Any ideas...?
Thank you everyone!
Thank you everyone!
Sounds like the same issue which there is a TSB out for when you are coming to a stop and you put the car in neutral then it stays steady around 2-2500 RPMS and then they dip back down to normal idle RPM while in neutral. Sounds like something in your tune.
