Interior Door panals
Old 07-06-2018, 04:36 PM
08'MustangDude
Banned
You can buy the pleather on eBay, precut and ready to install.
You use a can of 3M spray on headline/upholstery adhesive to replace or repair.
If repair, you need to remove the adhesive from the back of the leather. It rolls off with your
thumb, and takes a while...
REPAIR
REPLACE
08'MustangDude is offline
Old 07-07-2018, 06:39 PM
cthuener
Thank you it is a big help.
cthuener is offline
Old 07-08-2018, 11:27 AM
cthuener
are there any original material panels available?
cthuener is offline
Old 11-26-2018, 09:41 PM
Riverrat73
Riverrat73's Avatar
Thumbs up Door panel
Originally Posted by cthuener View Post
My interior door panels are coming off on my 2009 GT/CS. What Glue do you need to get them back on for good?
I have the same car and had to deal with it for the last 5 months. Option one is to take it to a shop and have them glue it the right way if you want to keep the original insert. Two buy some 3m upholstery glue from a hardware store and try to glue it yourself. Its a pain but possible. The only part of it is that you have to clean the surface real good, YouTube helps to show you how. Cheaper and takes time. The only part I could not get to stick was the edges of the panel that comes up to the panel. I had one last resort to super glue the edges to the actual panel. I sort of did most of it like that to make sure is really stuck too it. I did that due to the fact I'm going to change them out(Door panel) as they are damaged so I did not really care to much. hope this helps.
Riverrat73 is offline
Old 11-27-2018, 05:20 PM
08'MustangDude
Banned
Original is not made by ford anyway, it's the fake leather, or vinyl... Even if you bought
a whole door panel, that doesn't mean it won't happen again. The material back, and
door side has to be WELL cleaned in order for it to be adhered to the door panel. The
reason it fails again is because people don't clean the back of the material. All that old
glue has to come off.
eBay, you can buy new material...
Mr. D
Off Topic
833
06-19-2016 02:04 AM
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Interior Door panals
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
