GT vs V6
GT vs V6
i was looking at newtakeoff.com and i had a question. Are the gt springs, sway bars, and shocks the same as stock v6 ones? There only like 20 bucks for the springs and like 30 for all the shocks or whatever. Basically there cheap but are they worth it or should i just go top of the line as a normally do? or try to at least. Also are the gt brake rotors and calipers the same as v6`s?
i would assume the springs are not, the GT spring rate should be more since they have to support more weight (same thing for the struts) therefore if you put them on your car, you might possibly lift it a little bit rather than lowering it.
the gt brakes are not the same, in fact they are larger, but for the price it is a great deal for us v6 people because you can easily swap yours out for larger rotors and use the supplied caliper bracket included in what they send u. the caliper itself is exactly the same, so you can chose to use the new or the ones already on the car it doesnt matter. (using new is always better though) I did this and although i couldnt feel the difference, i kno its there especially with nearly 1" larger rotor that common sense.
and changing out the pads is also helpful to do at the same time, this did make a difference i could feel, i just used Hawk HPS street pads since i dont take it on the track. break dust is minimal.
It would make sense to be made to support more weight but i dunno. So its if-y on the springs and struts. And i get it with the rotors but i may just by some slotted and drilled rotors. I already got the hawk ceramic track brakes which are awesome.
...search and ye shall find...
- the rear springs are the same on GT and V6.
- the rear brakes (rotors and pads) are the same on GT and V6.
GT front springs are slightly stiffer.
Gt front swaybar is larger.
Dont waste money on rear take-off springs/brakes when you already have those same parts.
^+1
Spring rates are similar enough that they wont help at all (they're made for the heavier 4.6L), just stiffer as said before. I do not know enough about the struts, but I would imagine not much change there either, my suggestion is to save the money and put it toward some GT sway bars- night and day difference in handling...
Or go aftermarket for the springs, etc. from what I've heard, they never disappoint.
Good luck!
Good luck!
http://www.newtakeoff.com/mustang_gt...2005-2009.aspx
Will they fit the V-6, and would I need new pads? Is this an upgrade? I assumed they were due to the GT needing better brakes, but you know what happens when you assume! Thanks for not berating me if this is a dumb question.
I have the FRPP M-5300-K springs on my sixxer, which are designed for the GT.
I know they're lowering springs, not GT stock but it works great on the V6.
FRPP K:
http://www.americanmuscle.com/fr-2005-k-springs.html
FRPP N:
http://www.americanmuscle.com/n-springs-0511-v6.html
so using the the K springs will bring down the back the same as the N springs, but using the K springs in the front will bring it down less than the N springs (theoretically at least haha)
the rear brake calipers, rotors, and pads are exactly the same because of the same weight reason.
the front brake rotors are NOT the same, the GT are larger than the V6, but the front calipers and pads are the same. the way ford is able to do this (to save $ again) is to use different sized caliper brackets that hold the same calipers either smaller/closer to hub (V6) or larger/further from the hub (GT).
so very simplistically to change to GT brakes all you need really are the larger rotors and GT bracket. no pads or calipers are necessary, but if they come in the kit from newtakeoff for that cheap its worth just changing to new.
