Replacement screw/pins for the inside of the trunk.
I'm missing one of those screw/pins that secure the headlights inside the trunk. Any idea where I can find a replacement? Or the name of that specific screw so that I can order one online.
Thanks!
Thanks!
If you are talking about the stud that is attached to the brakelight "pod", I thought they were molded into the plastic. The stud goes through the body and a nut tightens and holds it in place. If thats the case, I don't know if you can just replace it. (I haven't had my brakes light out in a while so I could be mistaking though)
If you are talking about the plastic screw/stud that holds the plastic inside trunk liner in place, just go to a body shop supply place and they can sell you one for $1 or less.
If you are referring to the actual screw/stud thing, I have no idea where you can get a new one, but I am pretty sure you can replace them. Take one from the other light and bring it to a napa/autozone/etc or a hardware store and see if they can help.
You wont find those anywhere but the stealership or a junkyard.
They are such a miniscule part, they are not available online.
I believe they are a part of the taillight assembly and thats the
only way the dealer can order them. Whole taillight ASSEMBLY.
How did it disappear?
Did it come loose by itself?
If so, it should still be in the trunk area.
How did it get seperated from the stang anyhow?
You have headlights on the rear of your stang by the trunk area?
TfcCDR
09-14-2015 12:08 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
