Deliberating T3650 Swap...
Hello Gents
So despite running amsoil, my T5 has continued to grind at times albeit less frequent and severely. Im just straight unhappy with the entire driveline. SO
ive decided that for my next mod project im going to rebuild the entire drivetrain after the engine. Id use the SVT 3.73 rear off AM (Cant find any takeoffs anymoar ) an aluminum driveshaft from Shaftmasters, and a SPEC clutch. Questions being-
1. What clutch and flywheel would I want to use?
2. Where can I get a T3650 Tranny? OBVI there are takeoffs on Ebay but im leary of that.
3. What other parts would I need to complete the installaion of the T3650? Im going to assume the shifter so Id prolly go to a MGW or Hurst
And, of course, if anyone has had a problem with any of these parts or ideas please do speak up. Id rather look like an idiot here than spend a ton of $$$ on the wrong parts
Hello Gents
I am, but I am leaving for a semester abroad in London later today and my baby is holed up in a storage unit for 3 months IDK if I can handle the withdrawal
So Im planning a round of mods thats 3 months away
FWIW, I believe my dads Saleen S281 SC putting out 465 HP at the flywheel uses the T3650- and that says alot, because if the 3650 can handle that power w/o grinding, then it should be able to handle an Xcharged V6 no probs
+1, its also pretty much your only choice unless you are going to design your own lol!
