Manual Tranny fluid recommendation? (other than ATF)
Old 02-17-2012, 08:32 PM
  #21
stags
stags's Avatar
Order it from American Muscle
stags is offline
Old 02-18-2012, 10:35 AM
  #22
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by up_yours_7
So no amsoil in my town what's the next best thing? Mobil 1?
Um, www.amsoil.com ???
http://www.amsoil.com/mygarage/Produ...FORD+MUSTANG+O
157dB is offline
Old 02-20-2012, 04:10 PM
  #23
manuel86it
manuel86it's Avatar
i am confused too about the right fluid..
here in Italy it's quite easy to have Royal Purple products (plus we build cnc machinery and RP also supply oil for them), but for our TR3650 manual transmission (mine is a 2010 gt) it seems i can use both the synchromax or a 75W-90 max gear from Royal Purple.
i don't get the difference between these two product, except from that in technical sheets synchromax is more correct for automatic transmission, but it looks like many of you use this in manual transmission. so what's your advice? i want to gain smoothness in changing gears, so i'm looking for changing the fluid.
thanks!
manuel86it is offline
Old 02-20-2012, 06:55 PM
  #24
stags
stags's Avatar
Like we said. RUN from RP. They KILLED my transmission. And gear oil is a bad idea, its too thick for the synchros which will FRY if not properly lubricated
stags is offline
Old 02-21-2012, 09:44 AM
  #25
up_yours_7
up_yours_7's Avatar
What about b&m quick shift atf???
up_yours_7 is offline
Old 02-24-2012, 02:48 PM
  #26
157dB
Cut & Paste Expert
157dB's Avatar
Its OK but you will not get any of the 'quick shift' benefits
in a M/T transmission. So you are paying for an ATF fluid
designed to produce 'quick shift's in an automatic and
using it in a M/T that would not need any of the 'quick
shift' additives that makes it a high dollar ATF fluid.
W
W
W
A
M
S
O
I
L
C
O
M
157dB is offline
Thunderball
15
11-22-2015 11:49 PM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
09-25-2015 06:42 PM
Quick Reply: Manual Tranny fluid recommendation? (other than ATF)
