2005 Water Leak
2005 Water Leak
Hi Guys, I've had a nasty leak for sometime anytime that it rains. Once it was the issue where the area behind the battery fills because the drains are clogged. That is now fixed. I think now I'm having the issue where the water runs down the side of the window and unto the floor. I've gathered from other post and the TSB that I can fix that by removing the "cowl" which I think is that black rubbery thing (rubber sealant) and applying silicone behind it and replacing the rubber sealant. Sounds easy enough but I'm more of a visual person. Does anyone have pictures of how to do this?
jwog666
12-27-2021 08:09 PM
